It is currently Fri Jul 25, 2025 5:37 am
PostPosted: Fri May 04, 2007 2:23 pm
I've buffed for years using a local music store's buffing system. It's getting too expensive (and time consuming) to drive into town and do this. So I'm putting together a buffer here at my shop. Wahoo!
So... those of you who are real buff, er, I mean who have your own buffers, what size motor are you using? AND-- Are you happy with the amount of power you chose?
Or, put this way: What horsepower would you choose NOW that you know everything you know?
Many thanks in advance for your help here,
PostPosted: Fri May 04, 2007 2:40 pm
So far I've only done it by hand rubbing , or with a random orbit buffer, but I do it in the buff.
PostPosted: Fri May 04, 2007 2:59 pm
I use a Grizzly 2hp buffer with 12" wheels.  It does a very nice job and has power to spare.
PostPosted: Fri May 04, 2007 3:07 pm
I use the cheapest motor they had at Harbor Freight the day I bought mine. I don't know what it's rated at, but I'm sure it's pretty low hp.
I take it pretty easy when I buff. I'd rather take an extra 15-20 minutes to buff a guitar than burn through. So I don't need any more power than the cheapest HF motor offers. Maybe a more aggressive luthier would want more.
PostPosted: Fri May 04, 2007 3:59 pm
I use my lather or drill press. Both are 1 hp. The drill press is radial arm, so I can pull it out and turn it sideways.   I'm not saying this is the best way, but I can change speeds and it didn't cost me anything because I already had them. I just chuck up an arbor and use 10" buffing wheels.
PostPosted: Fri May 04, 2007 9:34 pm
Steve...Check out Caswell fot the entire works. Ocassionally they run a special where one can purchase the motor, stand and 14" buffs very reasonably. I bought my rig from them about 3 years ago for around $100.
PostPosted: Fri May 04, 2007 9:37 pm
Steve, you don't need a lot of horsepower to run a buffing set-up. I've got a home made set-up that I run with a used 1/3 hp 1725 rpm Baldor motor that has plenty of power to turn ganged 12" buffs.
On mine I can adjust the tension of the drive belt and keep it set pretty loose and I've yet to stall the buffs.
PostPosted: Fri May 04, 2007 9:51 pm
I use a 1 hp 1725 rpm also... mine was an old table saw motor i think.
Matt
PostPosted: Fri May 04, 2007 10:47 pm
    I use the Random oribital . I am building an arbor buffer and am planning 1/4 -1/3 HP. I am one that preferes longer to buff than faster to burn.
    Also I set the buffs so that I can stop them. I threw a finished guitar off one the first time I caught an edge. Not a fun experience
john hall
PostPosted: Fri May 04, 2007 11:00 pm
my setup is shop built, a go kart axle, ~$20.00 and a pair of pillow blocks ~$18.00, from a flea market. i bought some buffs from s-m, and more from caswell when they had a 2 for 1 sale on. couldn't resist. i had originally used an old 1/4 or 1/3 hp motor that i had been given. when it died last year i found a nos 1/4 hp dayton explosion proof motor for <$10.00 on ebay. even with the shipping it was <$20.00. of course i don't need the explosion proof feature but for the price i wasn't going to say no.
i purposely use a small motor to help avoid burn throughs. if you push too hard it will slip or stall and give warnings. it still gives ample power if you are using correct technique, and if you're not, a bigger motor is a safety hazard for the operator and the guitar. i guess i just like to be safe rather than sorry.
PostPosted: Fri May 04, 2007 11:16 pm
First name: Jim
Last Name: Kirby
I just put my first one together, following a plan in one of the Stew-Mac Shop Tips that is emailed these days. They recommend a 1/3 hp motor. I haven't had a chance to use it yet.
Jim Kirby
kirby@udel.edu
PostPosted: Fri May 04, 2007 11:49 pm
I'm planning on putting together a buffer soon but for now I'm using a random orbital and get surprisingly good results.
PostPosted: Sat May 05, 2007 12:47 am
Steve,
I have shop fox with 3/4 hp and 12" domet wheels and it works fine.
Check out Sylvan wells' site. He has a whole article on the parma system, it looks like a good rig.
We missed you at the LINT meeting, big turn out, 28 people in Chris' living room.
Matt Jacobs
"Don't tase me bro"
PostPosted: Sat May 05, 2007 12:51 am
Steve, Check with your local HVAC guys. My friend holds motors for me when they remove furnaces from homes. Many of the motors are 1725rpm and 1 HP. Buy your self a few pulleys and your buffing for the cost of the pulleys and buffs.
PostPosted: Sat May 05, 2007 2:07 am
I'd sat go at least 3/4 hp, Mine is 1/2 or so and I have to give the wheels a spin as I turn it on or it won't start. Next time I'll make my own and use a bigger motor. My buffer is the Shop fox from Grizzly, very similar to Stewmac's original buffer.
PostPosted: Sat May 05, 2007 2:37 am
Hi Steve,
I use the Stew Mac buffer with a 1/2 hp Baldor Farm Duty motor that I picked up on ebay....there is no way you can stop that thing from spinning with a guitar body, it has plenty of power. I think(from what I remember) it's final gearing has it spinning in the 800-900 rpm range.
Greg
Gwaltney Guitars
PostPosted: Sat May 05, 2007 4:16 am
I use a car style double handled buffer that has a 12" pad with 3 apron options for the pad. Obital style. Works great, cost little, and the guitar will not jump out of your hand and hit the floor.
PostPosted: Sat May 05, 2007 6:41 am
the fact that you can't stop it with the guitar body is the source of a potential problem, not a solution, particularly for those who use a waterbourne finish. i would still prefer not to have the problem.
if you burn through nitro it is usually no big deal to patch up. but burn through waterbourne and you usually have to strip the finish of and re finish to avoid the witness lines.
if you are uniformly attentive, always perfectly attuned to the pressure you are exerting, never so careless as to present to much of an edge, in short if your are always perfect in your buffing operations you won't have a problem with a bigger, more powerful motor.
i'm not so perfect, in fact a bit of an oaf, and need the extra bit of protection that the smaller motor offers when i am impatient, under pressure from a client, etc., and get in too much of a hurry, heavy handedly push too hard and inadvertently ask for disaster. then my nice little 1/4 hp motor oh so gently reminds me of my folly and encourages me to work in a proper manner.
PostPosted: Sat May 05, 2007 6:54 am
Last Name: Abercrombie
[QUOTE=John How] I'd sat go at least 3/4 hp, Mine is 1/2 or so and I have to give the wheels a spin as I turn it on or it won't start. Next time I'll make my own and use a bigger motor. [/QUOTE]
John-
Not that it is a problem, since you have a 'workaround', but...
My guess is that there is a problem with the starting winding/switch/capacitor (take your pick,depending on motor type) on your 1/2 HP motor. A buffer is not that hard to get spinning; usually a fractional motor will have no problem. If your motor has the usual starting winding and centrifugal switch arrangement, sometimes blowing out the crud from the end of the motor (with compressed air) will solve the problem. Otherwise it's usually a fairly easy disassemble and clean operation, if you like that sort of thng..
I use a 1/3 hp 1725 rpm motor salvaged from a swamp cooler, which has more than enough torque to spin the 12" buffs I use. Any motor that is intended to turn a squirrel cage should work fine.
A couple of pillow blocks, a go-cart axle (it's threaded correctly), a sheave to reduce the speed, a V-belt, and you're on your way.
John How, I suspect there might be something wrong with that motor you're using...
PostPosted: Sat May 05, 2007 7:08 am
First name: Greg
Last Name: Harrington
1/3 hp furnace motor on 12" buffs on cheap arbor mounted on 2x12 plank I can clamp to my bench with lots of overhang room. 2:1 reduction from 1725 to avoid heat. Wet and dry sand 600 thru 4000 and buff with red then ivory mazaerna,
any suggestiopns on coarseness of componds?
Greg
PostPosted: Sat May 05, 2007 7:49 am
My point was simply that the motor would not bog down as some have stated may happen with less powerful motors....I'm certainly attentive enough to realize when too much pressure is being exerted, so I don't see "enough power" as a potential problem.....I guess there are many ways to look at this setup....small motor that bogs down before burning through, loose belt that slips when too much pressure is exerted,etc....I like mine the way it is, if I want to put a little extra pressure I know I've got the setup to do so....and to date I've never had any issues with burn-throughs.....There seem to be many paths that one could take, choose the one that fits your style.
Cheers,
Greg
Gwaltney Guitars
PostPosted: Sat May 05, 2007 8:51 am
[QUOTE=ToddStock] You're better off creating slippage with the belt rather than stalling the motor. I run the belt just loose enough to give some slippage when I'm getting a little too frisky.[/QUOTE]
That's what I do too. I have the regular SM buffing arbor with 12" buffs, and I use the motor from my old lathe, I believe it is 500W (3/4 hp?), and I run it at about 900 RPM. Anyways, it is powerful enough with normal use; given half a chance it will also burn through lacquer or throw a guitar to the floor.
PostPosted: Sat May 05, 2007 1:52 pm
You guys have really come through, and I thank you!
So let's see, we have:
??? hp-- 1
1/4 hp-- 1 vote, w/ maybe another
1/3 hp-- 4 votes, w/ perhaps another
1/2 hp-- 2 votes, a 3rd user who wishes for more
3/4 hp-- 3 votes, w/ a wistful "someday-er"
1   hp-- 2 votes, w/ nary a complaint
2 hp-- there's a real MAN in the group!
Oh yes, and the few hand-held buffers amongst us-- 4 of you, and I know you get good results. (Did you know that Tony Ferguson has a hand-help buffing rig? And doesn't he do pretty work??)
JJ didn't really commit himself, did he?
And Hesh, I hear ya on those pesky b/w/b's!
Thanks guys, I'm not quite as confused as I was yesterday.
